Weird Lag problem (not network releated, Probably PCI)
Guntizzle
okay so here it goes
(Windows XP Pro btw)
This network problem is only my computer not any other computer on the network
I have 2 mobo LAN port and PCI wired and wireless card i've tried both, they all lag out
what happens is whenever i play a game that makes my video card kick in i get this weird ass lag which makes me think its something with my PCI settings, auto lags to high hell, its usually on and off but lately its been really bad and wont go back to normal
-ive tried probably every internet fix that could come to your mind, hell even reformatting (i suppose i will list all if you ask)
my only PCI BIOS Option is a PCI Latency Timer which is at 64 (ranges from 32 to maybe 260-ish in 32-intervals )
now i would think about buying a new mobo and getting that done, but if i do my case is watercooled and it would take an entire day to drain, replace parts refill,etc so if it calls for it, I guess i would, but your my last hope [H] Plz help :(
sounds weird. Motherboard problem? What motherboard do you have?
Clearly its a hardware issue.
Updating bios?
i actually havent tried updating my BIOS, i dont have a floppy :( suppose i can go out and buy one tho
mobo is Asus P5N-32 SLI SE Deluxe
Here's my BIOS PCI settings shots
bah i tried updating the BIOS with a boot CD doesn't work, only floppys
anyone have any other ideas in the mean time?
