weird issues.
hardnewbie
I am working on a friends system, and I have experienced some weird issues. The system specs are:
Sempron 2600+
K8NHA Grand nForce3 250GB
1 GB Buffalo PC3200 DDR
Radeon 9700 pro
40GB IBM Hard drive
DVD writer
300 watt Antec PS
When I first looked at it all it would do is boot to a message (CMOS Checksum Bad) Insert system disk into floppy drive to continue,
I flashed the bios to no avail, I then thought that maybe it could be something else beside a corrupted bios. I replaced the PS from a crappy 400 watt to an Antec 300 watt. Viola it booted now it locks up when trying to boot from the main drive. I tried another drive and it does the same thing just hard locks. It will not boot to knoppix either. Any suggestions? Thanks.
I did replace the battery and it only did it while the crappy 400 watt PS was in the machine. It is very strange.
Unplug any peripheral but main hard disk and videocard, load BIOS defaults and see if it boots this way? If so, then the power supply is not up to hold the radeon and other devices at the same time :(
That is my thought, but I did unplug everything but the radeon. It has to be plugged in to boot correct? Also before the PS change sometimes when booting I would get weird screen corruption like the video memory was going bad. I have another card I could try.
Well, well looks like the PS, CPU and memory took a dive. Replaced them and all is well. Funny stuff huh?
