Weird Issue
  • Thread starter Deleted member 109755
  • Start date
D
Guest
My system's configuration is.
Gigabyte K8NS-939
3200+ Venice
Kingston HyperX (2.6V) 512x2 pc3200
Ultra X-Connect 500w
BFG Tech. 6800 Ultra OC
Western Digital Raptor (36GB) 10K RPM, 8 MB Buffer.
SB Audigy 2
Now to the problem:
I get this "stuttering" during game play, where the game totally locks up for 2 to 4 seconds at a time. This also happens during benchmarks. Upon further investigation I found that the AGP Aperture is set at 128 MB, well that's a problem because my card is 256 MB. I can't tell if Fast Write or Side Band Addressing are turned on either. Those 2 options are supposed to be off according to BFG because they can cause problems with the 6 series GeForces. With this board, in the bios, I don't see an option to turn off either of those or adjust the aperture size. My question is: do any of you guys have any idea or know of any one who has had this same problem, because this really sucks. I can't really play anything or run any sort of benchmark because it's causing nothing but screw ups. I have the latest BIOS revision available for the board.
Any ideas?
Thanks!
Kevin
Having the apeture set at 125MB is unlikely to cause you significant stuttering issue - I have mine set at 128MB, and that's never caused a problem. What video drivers are you using? The new drivers from Nvidia have been known to create stuttering problems. Try using the generation of drivers prior to the 77.xxs and see if that helps.
Yeah but won't side band addressing and fast write also cause those problems in the 6 series cards, that's what BFG told me. I'm using the 77.30 drivers. (came with BF2 demo) and work perfectly thus far.
Edit: - Actually I was using the latest 77 series from Nvidia, and reverted to 77.30's from the BF2 demo, and that appears to have fixed the problem, atleast as far as I can tell. I'll keep close track of it and see if that cleared it up. Thanks for responding dude.
Well my 3d Mark 03 Score was 6934 3DMarks
And my 3d Mark 05 Score was 2692 3DMarks
The interesting things about these numbers are that in each program, the CPU marks are backwards. In 03, I got like 800+ CPU marks, in 05 I got 4088. These numbers confuse me. I don't really have a gauge for these numbers so could anybody really tell me if these numbers are good. One thing I really love about this AMD system (i'm usually an intel guy) is that the CPU stays so f'n cool. I'm running 86 degrees with the stock cooler. That's insane.
Well this sucks for me, that appears to have not fixed the problem. I REALLY think that it's the aperture size and the side band addressing. DOES ANYONE have any ideas about this board?
Thanks
