Weird Issue with My Computer not loading
Andrew_Carr
So right now my computer works about as well as it always has. But for some reason, trying to navigate through My Computer doesn't work. It just hangs.
If I use IE and type C:\ or D:\ it navigates to those just fine, but if I go to the next higher directory(My Computer), I get the same thing.
Could this have anything to do with having a lot of network drives that are no longer accessible?
most likely yes. If you eventually wait it will probably fail out.
You might also create a new profile and start using that one if it never fails out and lets you disconnect the drives.
