Weird issue when waking from sleep (6900xt)
The Cobra
Happy Sunday morning [H]'ers
So I've had my card for two weeks and I am very very happy with the overall performance so far.
One small glitch though: When waking up from power save, the monitor goes into the resolution of 1024x768!?!?!? YUGE text. A workaround I have discovered is either a reboot (initially) or just turn the monitor completely off for a second and turn it back on and the resolution is back to normal (3840x1600)
Any thoughts? Been doing this for both driver updates I have used.
Thank you
^^ that and you can try winkey+control+shift+b to reset the driver when it does it.
I would guess something with pcie power savings in win or bios, but cool trick to reset driver.
