/dev/null
- Mar 31, 2001
What do you guys think?
The "stars" of this project.......low rpm for low heat. # of spindles should make up for low rpm. According to specs, these use a MAX of 2.5W ea. 2.5 * 28 = 70W.
Qty 28: http://www.newegg.com/Product/Product.aspx?item=N82E16822149059
disk caching. Will use 64-bit linux for OS.
Qty 4: http://www.newegg.com/Product/Product.aspx?item=N82E16820141300
Hot swap. Gotta have it...7 * 4 = 28
Qty 7: http://www.newegg.com/Product/Product.aspx?item=N82E16816119012
cheap sata controlers for mdadm based raid. 2 = 16 ports
Qty 2: http://www.newegg.com/Product/Product.aspx?item=N82E16815121009
big cheap case, plenty of room. 7 x 5.25" bays for the hot swap backplanes
Qty 1: http://www.newegg.com/Product/Product.aspx?item=N82E16811128024
FSP generally makes good power supplies. Disks take MAX 2.5W upon spinup. Will this be sufficient? 45W proc is being used.
Qty 1: http://www.newegg.com/Product/Product.aspx?item=N82E16817104953
chosen for having 2 pci-x, 2 pci-e x1, 1 pci-x 16. What I/O!!!
Qty 1: http://www.newegg.com/Product/Product.aspx?item=N82E16813131026
chosen for a pci-e x1 slot. We don't want to hit pci bus limits.
Qty 1: http://www.newegg.com/Product/Product.aspx?item=N82E16816103058
Budget proc, low power. I had the fan die on one of these and it STILL ran without problems.
Qty 1: http://www.newegg.com/Product/Product.aspx?item=N82E16819103204
I know the spindles are super slow but with 28 disks hopefully raw # of disks makes up for some of the spindle slowness. If someone knows of 2.5" 7200rpm drives that make very low heat, I'm open to suggestions even if size is smaller.
I think this would make a great, fun project for an iscsi san.
16 ports are on the pci-x bus, 9 ports on the motherboard, and 4 on the pci-e x1 card. This gives us 29, incase one of the pci-e connectors breaks somewhere, we have an extra.
I suppose I forgot a video card, but whatever is cheapest/fanless/coolest I guess. (geforce 2 mx ? 6200?)
