What's going on? I idle at 41-42 (which seems high) but my cooling is very good, under load I don't even hit 50, gets to 49. This is really a narrow range, but I'd expect my idle to be lower. NO matter how many times I've reseated this config it's the same. I can't get my idle under 41!
Case probably has good negative air flow (2 antec fans on low in front and 120mm fan in back on medium). I've got an active coolermaster fan on my (passive NB chip).
I'm getting a powerful Silen-X 120 mm fan in a few days...two questions:
1. should I put this new 120 on the big typhoon or use it on high to create even more negative pressure in case.
2. should I put the active cooling fan on the NB or SB chip?
Thanks!!
Thanks!!
