Weird HDD issue? HAL.DLL error..
SSpiro
Not sure what the problem is..
I was having problems with my old motherboard (Asus P4S8X). It was dying, slowly. I replaced with a gigabyte motherboard. All the other hardware parts are the same.
I installed the new board without issue. Setup the hard drives the same. I unplugged my backup HDD (80gb with two partitions that I keep my all produced music, all my documents for work, and every digital photo I've ever taken for the past 6 years, including all vacations, family events, my wedding, etc) plus one or two VMWare systems. I wanted to make sure I didn't format the wrong drive! Little info: The backup drive is hooked up to an IDE expansion card.
I formatted the drive that is to be used as the main C drive, and installed a fresh copy of windows xp. After complete, I powered down and plugged in the backup drive. When I reboot, I get the dreadful "The missing or cannot find hal.dll, \windows\system32\hal.dll". and the system reboots. If I unplug the backup drive, the machine boots up just fine.
Sooooo.. wtf? Seriously? I CAN NOT LOSE what is on this drive, but I can't access the machine when it's hooked up. Help. :cry:
I'm thinking of going and getting an external IDE hard drive/usb case that is plug and play and hooking it up that way.. but seems like a temporary solution to a weird problem..
Sounds like a good solution to me. Can't you just run it off an IDE cable from the motherboard though? Even if it's just temporary.
Well, both channels on the primary IDE and secondary IDE are already being used. I suppose I could unplug one of the DVDRW drives and test it out..
