Weird graphics card and mobo combo?
CORVETTEZ06
Hey everyone,
I recently got the ASUS K8N-E Deluxe motherboard because my Chaintech VNF3-250 died on me. Strangely, the graphics card I have (eVGA 6600GT AGP w/ Zalman copper cooler and temperature mod flashed) reports higher temperatures than I had before. I used to be getting anywhere between 49 and 55 and now it is always around 62 to 63. Does anybody have any explanations? I felt the cooler on the actual graphics card and it doesn't seem like 62 is a realistic temperature for feeling fairly cool.
Also, what would ideal temperatures be? The threshold temperature it says is 145 degrees!? So would the mid 60's be okay for a 6600GT? Thanks for reading and attempting to help out.
solved i think
in the midst of moving all the hard ware components around when swapping motherboards, i think the Zalman graphics card cooler i have came a little loose. I just took out the 6600GT card and took off the cooler and reapplyed it and made sure the screws were tight with the washers and now i'm getting 47 degrees. Yey!
