Weird GPU brightness issue.
Kainzo
So i've had my GTX 460 for a little over a week, everything was going grand, until I had some issues with drivers and I had to uninstall and reinstall the nvidia ones, I did this correctly by ensuring everything was removed first, etc before a fresh driver was installed. Now, for some reason, the games i'm playing look extremely bright around certain lighting objects... In MW2 the rail cars that used to be pitch black, now look well lit, when everything else remains the same.
A few glazed textures also have much brighter qualities to them.. When playing Saboteur, the lamps that hit pictures with their light look extremely radiated, even when the gamma is turned way down. I checked all of the gamma / image settings in Npanel but all of them are set to default.
Has anyone run into this kind of issue before? I'm not sure how to fix it, I attempted to uninstall / reinstall the drivers again, but this did not seem to do the trick.
Pipe
http://i34.tinypic.com/5bqsqo.jpg
The pipe on the above image shows really bright, when i change angels it of course changes the lighting. It didn't look this bright previously and adjusting the gamma doesn't really help it much.
Vector/gun
http://i34.tinypic.com/nt4ki.jpg
You can see the gun is VERY bright. Almost intensely.
Attempting to take a screenshot of saboteur to show the extremeness that game shines.
Maybe i just didnt notice it... Although the lamps on saboteur are REALLY bright, though i can't print screen shit.
