ReconSniper
- Apr 3, 2002
Ok, my system specs are in my signature. Basically while I am in windows the system starts freezing, or going really slow. My mouse is skipping all over the place but I am not getting errors. I ctrl alt del and the task manager never loads even though I can select it from the menu. I cant click start or shutdown or anything. Basically Im done at this point. I hard shut down it by hitting the reset button. When the bios posts it sits at detecting hard drives. after a while it detects none and goes on to bootmgr not found. So i unplug it and wait a while then start back up. This time it finds the hard drives and boots fine. Sometimes I will not get the freezing in windows but when I start up it says boot mgr not found and I have to load off of the windows cd. Everything works and no hardware has been added recently to cause this. I was just wondering if it was the HD or the motherboard. Since both HD arent being detected I figured it had to be something. I have preordered windows 7 so Im planning on formatting anyways. Let me know what you guys think is going on.
