Weird display resolution during bootup for Dell 2405.
The native resolution on this screen is 1920x1200. One day I decide to try the 1280x1024 resolution with black bars. However, I decided to revert back, but the BIOS boot up screen that appears when the computer turns on still appears as 1280x1024. How do I fix that so it shows up as 1920x1200? Thanks.
BIOS resolution is fixed and cant be changed, try changing the expanding options of the LCD.
The thing is that the BIOS screen was stretched to fill the entire screen. Now it only occupies a fraction of the screen, but it does stretch to 1920x1200 after Windows boot up.
Same for mine, cept I never switched it to 1280x1024, It's what your BIOS is programmed to display in.... does it really bother you?
peacetilence said:
You probably had the monitor set to strech lower resolutions, now it's set to aspect.
exactly, in order to change it he has to set the display to a lower res than native first, and then change it back to fill screen
I don't know what the original settings were, but the BIOS screen did occupied the entire screen.
