Weird counterstrike problem on 8800gtx
hmboy
Hello, in CS_assault, when i shoot the top back door with the Terrorist starting pistol, then look at it from an angle or from far away (close to garage door) then it goes all blocky and weird.
Can anyone else confirm this for me on their pc?
This is on a completely fresh install with latest drivers + fresh steam download/verified.
running at 1680x1050 with everything in cs on highest and graphics driver all on default
I have not noticed any other errors, and extensive googling has not returned any answers.
Thanks
if you search google or these forums you will find that there is a known issue with 8800 series cards and HL2/Source games. The problem is that certain objects and or textures in the distance don't look right, they are all too "light". Valve and Nvidia are working on it...
valve is sapost to release an update to fix g80s problems
the only prob i have is when their is fog people in at distances appear light brown so i cant tell if they are t or ct.
i dont think this is the problem i am experiancing, as when i use the fix for that grey bug (directx81) it does not fix this.
Can anyone please test what i am doing on their 8800gtx to confirm if i have a hardware fault?
Thanks
i cant see one object being shot at becoming strange a hardware problem... it most likely has to do with another valve/nvidia bug that is yet to be fixed.
It's the same with me, too, or at least it used to be. From far away, the shadows didn't seem to be rendering correctly or something. Up close it was fine.
A driver change fixed this. I believe I went from 93.71 to 93.81 or 92.91.
My recommendation is that you either reinstall your drivers or use different ones.
