Weird Counter-Strike LAG, HELP (Link)
Status
Not open for further replies.
First, reposting the same thread is a good way to piss off the mods.
Second, you got a good answer to start in your other thread. If it's latency of the network connection, it could be your network setup, your NIC, your ISP, the game server, etc.
If it's FPS lag, you may have a process running in the background that's slowing it down, you may have a need for newer video drivers, you may not have something configured right, or tweaked right, etc.
You don't gives us that much info, and this is the kind of problem an internet board isn't going to be able to help with. You have to try a bunch of the typical troubleshooting methods, and figure it out.
bingo.
if your thread doesn't get too much traffic, put it in your profile and become active on the [H]; the more you post intelligently, the more people will be curious enough to read your profile, the more people will see the link to your thread etc. etc....
...yes, indeed, double posting the same thread in different forums is very much frowned on. As such....
Thanks - B.B.S.
Status
