Weird Cooling Problem
Hawkskater
Hey Everyone,
I have an ABS diablo advanced w/ titanium bezel super tower. It has 2 large intake fans on the top of the case. I noticed that when I have them at full RPM the case temp is around 33C but when I have the fans at there lowest RPM the case temp is 30C how is this even possible? Thanks
to much positive pressure.. theres not enough exhaust fans to remove the air your pushing into the case.. so it just creates a big heat pocket inside the case..
Are you sure those are intake fans and not exhaust fans? I have seen the case and it has a big front fan and side fan, both of which are intakes, the top fans should be exhaust fans, if you have them turned around, I would suggest turning them and making them exhaust fans and see what kind of temps you are getting.
