Hardware setup:
Intel E4300 @ 9x334 1.375v
2x1GB OCZ PC-6400 Platinum Rev 2 @ 668MHz, stock timings
Gigabyte GA-965P-DS3
Nvidia GeForce 7900GTO
Winfast TV2000 XP Deluxe
WD 74gb Raptor
Seagate 200gb
OCZ Powerstream 420
Set things up and things were running ok for a few days. Did various stability testing. One day during a game of War3 the system froze. Reboot, blank screen, no post, computer rebooted a few times on its own and eventually posted.
OK, that's a bit weird, so I ran some stability tests again (I did it initially when trying to OC). The computer ran Orthos stress (CPU + RAM) and 2 instances of rthdribl (each one had affinity set to 1 of the 2 cores) for 18 hours with no problems. So I figure, ok, everything's stable, maybe it's the vid card (was getting some L2 -> L1 overheating issues in the system menu), so I reset the video card to stock.
Second freeze I came home from work and my computer was on, with the monitors in standby. I moved the mouse and they woke up, however, the cursor wasn't moving and the computer was non responsive. Again, really weird.
Third freeze was when I was watching some TV with my TV tuner and browsing some websites and the comp freezes again (mouse locks up but the LED stays on), keyboard non responsive, displays frozen. However, somehow I am still getting sound from the TV tuner. I wasn't doing anything stressful with the PC at the time. Reboot, same issue, unplugged the PSU and started the comp, plugged it back in and it booted fine.
Anyone have ANY idea what's up? I am starting to suspect the RAM and will memtest later, but right now it's underclocked (668MHz instead of 800MHz) and at stock timings, so who knows. After a freeze I tried memtest86+ and was getting a bunch of errors, however, upon reboot again, memtest ran fine.
Maybe it's a driver issue with the 7900GTO? If the comp totally crashed, it seems odd that there would still be sound being processed since it's onboard sound and the CPU would have to still be working (I kept the computer on for a few minutes just to make sure it wasn't buffered or something). However everything else was frozen, keyboard wouldn't work, ctrl alt del etc. didn't work. Second freeze, the computer seemed to be frozen however moving the mouse woke the monitors up out of standby mode, which again seems to indicate some sort of processing is going on. So I'm at a bit of a loss at what the issue is; the comp's frozen once during gaming and twice when not doing anything stressful, and even though the display wasn't updating, it seems like the computer is still "on" so to speak.
I've run Orthos for hours on end with no issues (both small FFT and blend tests) with no issues. Vdimm is 1.9v (maybe needs 2.1?), but MCH/FSB voltage is stock (auto) in the BIOS. Again, I think it could be the video card or the RAM, but even if it is the video card, why was Memtest being all weird one time after a reboot? Seems strange. And if it's an MCH/FSB/CPU issue, why can orthos and rthdribl run fine for 18 hours?
If anyone has any idea what other stability tests I can run that would definitively identify the problem, that would be appreciated. Please, no "DS3 sucks" posts without any suggestions since I am not even sure it's the board yet. Especially since it boots normally and then the comp just freezes totally at random. I will run a full Memtest86 test later tonight, but if anyone has anything elese they can suggest in the mean time that may diagnose the problem faster it would be appreciated.
WD 74gb Raptor
Seagate 200gb
OCZ Powerstream 420
