Weird Color on Videos
EnderW
I just put together a SB75G2 system. When I play certain video files, the color is all purple and green and way off. Any ideas?
I already installed all windows updates and latest ati video drivers.
reinstalled windows, and used the 4.8 cats this time, everything is fine now
WillowHawk said:
erm..good troubleshooting..i think maybe a codec could have fixedt hat....maybe
yeah maybe, but I tried diff codecs and nothing seemed to be working
I think it may have been b/c I forgot to install dx9 until after I installed the ati cat drivers
oh well, it was a borked install anyway
OK, I'm having this same problem again on my new system.
Only way they will play is with Windows Media Player if I goto Options > Performance > Video acceleration and change it to none.
I already tried a fresh install with no luck - Media Player Classic won't play without the weird green and purple, but will play on my brother's computer just fine
Bad video ram? Have you tried this video card in another system? If its ok its just codecs.
no, but it passes 3DMark05 and the artifect check in ATI Tool
Try videos with different codecs. Do you game on it at all and if you do is there any issues?
haven't tried any games
only certain videos do it, they are all .wmv files
