I ran into a strange CCC issue starting with the 11.4 pre-release, but this issue continues with the 11.4 Full release.
In my system I have 2 6950's (6970 mod) in crossfire. Prior to 11.4, I could set manual fan speed independently, on both cards, and everything was great. When I switched to the 11.4 pre-release, and even now with the full release, I have noticed that the manual fan speed control is only working for one card (primary). You can increase the fan speed on the second card but it does not actually change ...
... but if I fire up GPU-Z ...
The second cards fan fires up to the correct speed (you can hear it ramp up). Sometimes doing this will cause the display driver to crash, shortly afterward, which causes the second cards fan to slow back down (again you can hear this)
I have tried removing / uninstalling CCC and then reinstalling the new divers, but it doesn't appear to fix the issue.
Has anyone else experienced this issue? Perhaps someone could try to see if both fans are changing speeds?
