Weird beep code after boot
xwwwx
I have a GA-P67A-UD3-B3 + Intel i5 2500k + ATI Saphire 6950 1GB + 2x4gb G.Skill RipJaws Series + PSU CoolerMaster GX650w.
The computer boots just fine, I get the "one beep" on post, and I can get into the OS (w7 or ubuntu 11.04 with dual boot). But after a while of using it I get a strange beep code, I couldn't identify what kind of beep code is it, and couldn't find any info online or even asking gigabyte support, I uploaded the beep code here so you can listen to it: http://kiwi6.com/file/mx750tt335 or here http://www.zshare.net/audio/98880046f982b8e4/
I tough it may be a temp or fan failure alarm, since it appears inside the OS and not on boot like normal beep codes, but I tried disabling all the alarms on the bios and the beep still appears, also I monitored the temperature while the beep code appears and it doesn't look too hot:
Hardware sensors Monitor 4.5 shows:
Mainboard: 25c
CPU1: 44c
CPU0: 46c
HDD: 37c
Chassis Fan Speed: 1950RPM
Voltages:
+12v : +12.04v
+5v: +5.07v
+3.3v: +3.38V
Core: 1.33v
Aux: 1.02v
SpeedFan show temps:
Core0 : 44c
Core1: 45c
Core1: 42c
Core3: 46c
HD0: 39C
Temp1:42c
Temp2: 25c
Temp3: 36c
Fan speed: 1929rpm
And from the bios (pc health status section) just after the beeps:
System Temp: 45c
CPU Temp: 48c
CPU Fan Speed: 2327RPM
VCore: 1.212v
DDR15V: 1.536v
+12v: 12.073v
Vcc3: 3.383v
Vcc: 5.083v
Vtt: 1.088v
Does someone knows what could be causing this beep code?
I ran memtest from memtest.org and it didn't found any errors.
If it is a power supply error, could it be the electrical network providing less power than normal or it can be only caused by a bad PSU?
Wait, is this coming from the OS over the normal speakers? If so, it's for sure some software running.
Have some sort of UPS software?
No no, the beeps come from the tiny speaker you connect to the motherboard. No software involved, it even beeped from bios a few times after leaving it there for like 15 minutes.
Also it doesn't seem to be an OS related problem since I used both w7 and ubuntu 11.04 and beeped on both.
