Hey all, I purchased an acrylic case for a friend and built it up. Everythings running fine but theres a weird issue with the amount and type of noise being generated from the case. From the fans that are pulling air in through the slats on the case, there is a loud hum, a very rhythmic or cyclic kind of high frequency sound..very odd. You can hear it from across the house, but when you're right next to it and sitting there for a while you actually get so used to it it's not that annoying. The fan on the back of the machine exhausts air through an open hole, no slats covering the hole, and the sound isn't heard there. If you cover up the front hole, probably 80% of the sound goes away, and the two intakes on the side panel when covered up account for the rest.
Could this be caused by the slats covering the fan holes? It's your run-of-the-mill acrylic case, I'd hate to have to cut those out but the sound is so annoying (to his wife hehe) that it's just going to have to be fixed.
Here's a picture of the case so you can see what I mean when I say 'slats'. They're like cut out grills..hard to explain but look at the pic and you'll see what I mean.
Any help would be appreciated !
Croww
http://images10.newegg.com/productimage/11-171-002-16.JPG
FLECOM's Note: Do NOT link directly to pictures hosted on other peoples servers.
Croww
