Weird 9/16-18 UNF
Zyklon808
I picked up a 120mm radiator, the CoolRad-12T. It has this for the holes:
· Threaded ports compatible with o-ring seal, 9/16-18 UNF tube fittings
Now how the hell do I screw in my 1/2 3/4th fittings on this? Is there an adapter?
I guess I could use the barbs if I -have- to.. =(
You would need to find an adapter to convert to G 1/4" threads most likely, I didn't find anything obvious from google which means if it does exist it will be expensive. Probably easier to use barbs, and likely cheaper to buy a new radiator. A 120mm radiator that has G 1/4" threads is likely cheaper than buying 2 adapters.
EDIT:
https://shop.hansa-flex.com/en/line-technology/adapters/straight/bsp-internal-threads/g-ir-hj.html
G IR 04 HJ 06 - This should be what you need, not sure how to buy it though. I still think you are better off buying a new radiator for $40 instead of spending $20 (or more) on some adapters
