Web Video Streaming: What's the best format? Please help :)
pcbananas
Good morning,
I would like to find out what would be the best way to allows users at a remote location on a 768K frame relay to watch a 1 hour video? What format should I use and how to deploy/publish this video?
FLV, WMV, MOV, ????
Thank you!
I say base your decision more on what is going to be easiest for your visitors to watch the video feed as quickly as possible. If most of your visitors are running Mac OS, then Quicktime may be the better choice, or WMV if most people are running Windows OS.
flv so all of the above + linux can watch..why do u think youtube uses it? altho i guess w/ such a limited audience u can probably choose whatever gives the best quality/compression ratio
