wdf01000.sys
Shalantas
File is missing or corrupt \windows\system32\drivers\wdf01000.sys. happen 50% of the time i boot my computer. afraid this will cause future issues. Ive ran the windows repair. IT wants a system restore. did it. problem still not solved now i have to reinstall a bunch of crap again. i ran a command prompt system check and it says all my files are good....what am i supposed to do. o and also some short cuts i have display as unkown file type icons rather then the actuall icon for the game. not sure if this is related.
It sounds like you've either got some nasty spyware, or a failing hard drive... or both.
Are you scanning with anti-virus and anti-spyware applications?
im using freeware programs ad aware se and avast anti virus. never had any problems with xp. of course this whole rig is an entirely new build. whats throwing me off is there are alot of people with this issue. some fix it some dont. highly doubt its hard drive failure though i think i would be having more problems then this. i really hope its not hdd failure. or i may just have to hate western digital for a while. lol
