WD6401AALS vs WD7501AALS
dson
I'm not sure which one to get. The difference in cost is 5 dollars and I was wondering if I go for the 750gb, will it be just as fast as the 640gb or noticeably slower?
well i have 3 of the wd 640gb 16mb cache drives, they will be faster than the 750gb drive, just look at some reviews of the 640gb and you should see a 500gb or 750gb drive in there to compare with.
i personally want the extra speed so i would recommend the 640gb drive.
it depends on how badly you want/need space.
While the 640 will prolly benchmark a little faster, the difference in real life performance will be imperceptible.
Don
