WD2500PM speed problem
m0tion
I got a WD2500PM (250GB, 8MB Cache, 7200RPM) for christmas and installed it, everything was fine. I don't think I'd ever run a SiSoft benchmark on it, but I noticed my computer seemed a little laggy recently and that it was accessing the hard drive a lot. I decided to run the SiSoft Benchmark and the drive scored around 21MB/sec !!! This is way off from where the scores should be, how can I improve my hard drive preformance?
System:
Chaintech 7NIF2 (Nforce 2)
2x256MB RAM (512MB)
Athlon XP clocked 1970MHz
WD2500PM
Windows XP PRO SP1
I have the drive connected to the motherboard with my DVD-Drive as it's slave. When I took the benchmarks there was no disc in the DVD drive. I checked in "Device Manager" and it's seems like DMA is enabled. While I was taking the benchmark nothing was accessing the hard drive, the computer was idle.
Your problem is you should never have optical drivers on same channel as hard drives. Move dvd to another channel and hard drives on its own channel.
