If temperature data reported by SMART is accurate, it would seem the latest WD2500JS Caviar SE drives are running a bit hot!
I've tested 2 new WD3200JS drives (dated Sep-2005 & Nov-2005) on a 1-drive system with left & right case panels removed; room temp 23°C.
HDD: WD2500JS-56MHB1
Firmware: 10.02E01
Date: 29-SEP-2005
Idle temp: 55°C
Stress temp: 61°C
By comparaison, tests were also performed on another system (closed case, 1 HDD, 1 rear case fan).
HDD: WD2500JS-00MHB0
Firmware: 02.01C03
Idle temp: 39°C
Stress temp: 46°C
I believe that recent WD2500JS drives are running too hot: causing reduced reliability, shortening lifespan. What do you thing?
Firmware: 10.02E01
Date: 29-SEP-2005
Idle temp: 55°C
Stress temp: 61°C
Firmware: 02.01C03
Idle temp: 39°C
Stress temp: 46°C
