laukinisvilkas
- Dec 9, 2009
After reading quite a bit around the net the WD20EARS is in my case. I'm using Win 7 and formated it as single volume with all the default options. Is there a way to test if WD advanced format is actually set right(+ is cluster(?) size 4kb)? Right now I'm running WD lifeguard extended test. It's also 1.81TB size, shouldn't there be more space from all that advanced formating? Should I be worried about head parking and any other issues since hard drive is going to be accessed once or twice a day. And what about in WD site mentioned
adjusting power options... The only option I found about hard drives in win 7 was about then to put hard drives to sleep.
Thank you for time and help.
