- Aug 9, 2009
Just installed my WD15EARS into my windows 7 pro 64-bit machine. It is going to be used to backup my Raid 5 array, which installed in a separate computer.
I got the disk installed, i went to disk management and it says the drive needs to be initialized.
It gives me the option of selecting GPT or MBR, From what I have read online, i would imagine GPT would be the correct choice for my application. Can someone verify this?
Also, since this is one of those new 4k advanced format drives, I wasn't sure if I needed to do anything else to ensure optimal performance.
According to WD I don't need to do anything, but I still want a second opinion.
Thanks.
Thanks.
