WD WD6400 Transfer speeds
ep3w
Just got my Western Digital WD6400AAKS 640GB drive today. I am running it right now using an esata enclousre and an express card sata controller on my notebook. Just curious as to if the HD Tune speeds look about right. The average seems to be right around what I here they are normally, but it looks to me like it might almost be bottlenecking in the beginning since its so flat, or is this normal? Either way its still about 3 times faster than my internal :D
Mine stays flat across the entire benchmark, so I guess "flat" is normal. Either way, that's pretttydecent for a single drive.
Your speed seems a little low. The typical Maximum for these drives is around 115MB/sec. So yeah you could be hitting some sort of limitation but I doubt you'd see any real world difference.
Here are my two 6400AAKS in RAID 0
Minimum: 98.5 MB/sec
Maximum: 168.5 MB/sec
Average 142.2 MB/sec
Access Time: 13.9
Burst Rate 102.8 MB/sec
It does seem to be hitting some sort of bottleneck, the burst rate seems pretty low too. I will have to see if updating the bios on the controller will help, otherwise like it was said I doubt I will notice much real life performance difference anyways. I was just curious as to how well it performed using an enclosure with the controller compared to internal.
Here is another WD6400 in an IcyDock external enclosure hooked-up via eSATA.
I'll run a test on my eSATA drive (as soon as it formats) so you can compare.
Awesome thanks :) By the way do you know about how long it is taking to format yours? Seems like it took mine at least 2 hours, it went pretty constant thought it didn't seem to hang at any point.
I did a quick format on the external drive. Will probably reformat before I start saving Norton Ghost images on it. I want to get my system 100% set-up, Ghost and then start overclocking.
Does Raid0 help with these drives in a gaming build? Because i can see that the access time has increased although the other rates have increased also.
RAID 0 is a hit and miss topic, some swear that it makes a huge difference, others say it is a waste. I use to have RAID 0 for 74gb Raptors, now I use them just as single drives, I don't think I will go back to RAID 0 again solely because my OS is now on 1 Raptor, all my games on aother so one drive is just loading the games nothing else. Makes it that much faster but again just my opinion of this, someone else will say it differently.
Access Time: 13.9
I have two 150X raptors in Raid 0..I multitask a lot and have a lot of data...the thing that bugs the crap out of me....with these is the noise....getting two of these and raiding them like how you did, Would I be able to achieve the same performance or better<>?
I would get rid of these just because of the noise, however, I really don't want to sacrifice any performance. Sorry to ask almost the same question again, but would like some more opinions on this.
Sorry if this is a basic question, but I heard the AAKS part of the model for wd hd's runs quicker. Was trying to find out if this was true or not.
Right now I am running the WD800JD, and it has slowly been decreasing in performance (I've had it for ~4 years).
I saw this on the new deals
http://www.hardforum.com/showthread.php?t=1315996
and was wondering if it was the real deal for the price
Got my WD6400 recently but the minimum transfer rate seems a bit low. This is how my HD Tune looks. Is it within "normal" parameters?
Thanks
