WD WD1003FZEX 1TB access time issues
gmreplay
I've been searching around for a couple of hours now and it seems that a lot of people are having issues with their WD1003FZEX 1TB drives. They say that the access times are in the 15-20ms range, which is on par with the Blue line of drives, and not at all near the 10-13ms access times that people get on the other Black drives.
Some people are even claiming that WD has just relabeled their Blue drives as Black, and are charging $20 more for them. I want to be sure about this before I buy anything.
Is anyone using a WD1003FZEX 1TB, and if so can you post results from HD Tune? Anyone else heard about this access time issue?
Links:
Drive: http://www.amazon.com/Western-Digital-Cache-Desktop-WD1003FZEX/dp/B00FJRS6FU
WD forum thread: http://community.wd.com/t5/Desktop-...-BLACK-poor-access-time-explained/td-p/658549
French site thread: http://translate.google.com/transla...X+forum&start=10&sa=N&hl=en&biw=2560&bih=1339
Overclock.net thread: http://www.overclock.net/t/1446170/western-digital-1tb-wd1003fzex-poor-access-time
If you have workloads that are access time sensitive, why waste energy trying to work out a 5-7ms differential between HDD models and just move the workloads to an SSD with sub ms access times?
With due respect, that is my thought as well. All of the major spinners perform about the same but if performance is key, it is much easier to just throw an SSD in. 250Giggers are pretty inexpensive and have a ton of space for working with. Shoot, I roll with a 120GB and Adobe CC suite installed and Office 2013 with browsers, codecs, all kinds of junk I still have 86GB to play with.
I agree with the above statements. In this day and age if you want speed there is no reason to opt out of a SSD. You don't need a large one, you can then invest in a overly large HDD where speed wont matter at that point.
It sounds like that was just a bad model from WD. I would love to believe they were so short on drives from the floods that they re-badged Blue drives to Black ones, but I think it's really just a crappy firmware issue or some flaw in that model that they can't easily fix. Seems to be a 1TB model issue only.
Something to note. Pretty much every difference between Black, Blue, Red, Purple, and Green drives is just firmware changes. There are some hardware differences (number of platters, RPM, etc.) but most performance issues these days and product line differences are down to how the firmware is programmed/optimized for the specific drive.
And warranty...
Sorry for not noting this earlier, but I am using a SSD. However, I keep a large number of games on my HDD that don't fit on the SSD, and I want the HDD to be as snappy as possible.
