Hey guys,
I've currently got a HTPC setup at home and I have a few questions. First, here are the specs.
Norco 4224 case
Areca 1880i
HP SAS Expander
12x3TB Seagate (ST3000DM001) in Raid6
I basically use it to store and play movies/tv shows to my tv and as NAS.
Background:
I've had 4 drives fail so far and drop from the raid. 2 actually died where they could not be read in another pc/boot up. (you could hear clicking noises). But the other 2, only "timed-out" and when plugged into another pc, they spun up fine and passed the Seatools tests.
I have an IT professional at work who's suggested I use the WD Red 3TB NAS drives (WD30EFRX)
Here are my questions;
1) Why would the drives "die" in the raid, but still be able to be read and pass all Seatools tests? More importantly, is there any way to make those Seagate's "usable" in my server again?
2) Would the WD Red drives work well with my setup? I know some other WD drives spin down when not in use and could cause issues in Raid setups. But seeing as how these are NAS drives, I think they should be ok. But wanted to check with you guys to confirm.
3) I also know that it is generally advised against mixing drives in an array. My IT pro says it shouldn't be an issue, but again, I wanted to check with you guys.
Let me know if you need any other info. Thanks.
Norco 4224 case
Areca 1880i
HP SAS Expander
Background:
