HGST work well too and seem to be relatively cheaper in price. Love WD Red. I have 2x 4Tb in my NAS for two years now. No issues. Still running.
If you cant find the Red pros try the HGST Deskstar NAS 6tb drives,
I had a 25% failure rate
WD Red Pro drives I bought a few months back are amazing IMO.
How many drives?
My experience with red drives is they are pretty slow compared even to 5XXX RPM HGST drives. Are the pros faster?
Red Pros have a 5 year warranty, these HGST are only 3
Remember the OP is asking about Red Pros. They are completely different drives than the plain Reds. I had a 25% failure rate on plain WD Reds but these WD Red Pro drives I bought a few months back are amazing IMO.
just 4 drives... but still I've had zero dead drives of any other kind.
Red Pros are 7200RPM and still quiet.
You are lucky. For the last 5 or so years I RMA ~20 drives a year out of around 200 drives that spin 24/7/365. With that said this year the number will go down substantially. I believe only 4 drives have failed (that are still under warranty) with 3 of these being enterprise drives..
Which make/model out of the 20/year you replace are most common ?
you are correct about the warranty difference, but Red Pros and the HGST NAS drives are still very similar in speed and reliability regardless of the warranty offered. Plus the HGST drives are less expensive.
I could see someone caring about warranty if they are buying a lot of drives because if 1 of 3 drive fails after 3 years I would likely just upgrade it, but if I have a large quantity of drives this could be an issue where the 2 extra years of insurance is very nice.
Would you say the RED Pros are more silent than the HGST NAS drives? MY only issue with the HGST NAS drives is I wish thaey were closer to the sound levels of the WD Reds, but I just figured all 7200rpm drives are going to make a bit more noise. I would get the 5400RPM versions from HGST but for some reason they are more expensive.
Damn. The prices at amazon on these drives have hit $379. They must be hard to get I guess. I bought 24 at $279 but they are on backorder.
