wd or hitachi hdd?
extrafuzzyllama
hi all i just bought a owc dual bay enclosure and am thinking on getting either two 2tb caviar blacks or two 2tb hitachi deskstar 7k2000
but i am not sure which because i want something that is reliable and works well
i was thinking of getting a gtechnology drive but they are pretty expensive but i heard they are really reliable and i think they use hitachi drives
i just would like some advice on which to get
Any drive from any manufacturer can and will die at any time. At work 1% to 7% of all our drives die each year. This year I had 11 drives die. 6 of these were under warranty. 5 of these warranty drives were 2 year old seagate 7200.11s and also a 6 month old WDC black 1TB. Make sure you have at least 1 backup of your important data. The rest were 5 year old WDC 250GB drives and one PATA drive.
Not sure what that is. Never heard of it.
There are only 5 drive manufacturers, Seagate, WD, Hitachi, Samsung and (Toshiba?)
Edit (they are hitachi drives in a macintosh styled metal enclosure).
http://g-technology.com/
You'll most likely hear arguments for both, and the truth is either brand will probably work just fine for a long time.
Personally, I've had nothing but good times with WD drives (*knock on wood*) and highly recommend them. The only manufacturer I've had a lot of problems with over the years is Seagate.
