WD hard drive questions...
berzin
1) Both of these hard drives have different model numbers and are $50 apart in price yet they have the same exact specifications. What then is the difference between the two?
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136313
2) Also, I was looking at this WD Raptor drive and noticed that it is marked "recertified". What does that mean?
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136364
Any help will be appreciated.
the RE3 is a enterprise class hard drive and are rated for true 24/7 use for a longer period of time then the black version..
recertified means it was RMA'd and either fixed and/or tested and passed and is being resold..
also the 160 gig version of the raptor was originally made for dell only to sell but i guess newegg finally got them.. only about a year 1/2 to late..
The RE3 WD1002FBYS is an enterprise drive that is used primarily in workstations and servers. Here is the product page for it.
A recertified product is one that was returned to the manufacturer, "cleaned up" (to test for and/or fix any problems that it may have), and then sent back to be sold as an "open box" model (with no accessories). Because a recertified item may have had problems in the past, it poses more of a risk of malfunctioning (or being DOA) than an unopened, unused retail (or OEM) item.
Regardless, that Raptor is a poor choice when the WD6400AAKS is known to be able to compete with (and even beat) it in most benchmarks. Plus, it's cheaper.
(I know, it's just a different way of explaining the same things.)
I was going to use the Raptor(I'm running the old 74 gig Raptor and wanted to upgrade to the 150 gig) for the OS and whatever other programs I use, with two separate 1 Terrabyte hard drives(one for audio, the other for video).
You're saying the one you are recommending over the Raptor will be better for what I will use it for?
if your going raptor you might as well buy the 150GB VR.. you cant even compare the old raptor to the new VR.. the VR is in a league of its own..
I'd go with the WD 640GB Black as the OS drive. If you use the 1TB drives frequently and speed is of utmost importance, go with the 1TB Black drives. If you don't use the drives often and just play music files from them, then you can go with the 1TB Green.
WD6400AAKS for $60 is the best value (best performance for your money). New VRaptor, then WD6400AAKS, and then the old 2nd gen Raptor...
New VRaptor...
New WD6400AAKS...
Old 2nd Gen Raptor...
Also, Enterprise drives are optimized for RAID (google TLER if you want to know more).
