WD Green ok in RAID 5?
TheSpoon
I've read that TLER cannot be enabled on new WD consumer drives, so does that mean that I shouldn't use them in a RAID 5 array? If so, can anyone recommend drives that I should use?
My goal is to build a very modestly-sized backup machine from spare parts (except the drives), using Linux's built-in RAID-5 implementation. I was thinking of getting 3 2TB drives, which should last me a while.
Thanks for any input!
TLER is pretty mandatory on Windows; but not on non-Windows OS. So you should be able to use your Greens without any timeout-related issues on Linux and other non-Windows systems
But i don't think flashing Green drives with RE-firmware will work; the whole idea of RE is that you pay them for 'paid firmware' with additional features like TLER. You don't need those on non-Windows OS, and you may want to disable TLER if enabled by default (such as with RAID edition disks).
Thanks for your replies! So do you know what mdadm does if it encounters a drive that's unresponsive for a few minutes?
