WD Green For File Servers
Carlosinfl
Loves the juice
I have a system with two Western Digital Black S-ATA drives and was planning on using them for the O.S. (Debian Linux) and then I have four identical 1TB drives Western Digital Green I was planning on using in RAID 5 array on a separate partition for a data storage folder. My question is how well do you think this would work using the black drives at the O.S. in RAID 1 and the four green drives as RAID 5 for the file partition?
Should work just fine...
I've been running 10 x 1TB WD green drives for over 2 years without a single glitch. I'm also running 50 x 2TB WD green drives as my media server for the past few month and so far everything is working great.
I don't run any black drives (I use SSDs as my OS drives) but I don't see any issues with using two WD black drives in RAID1 for the OS. I believe a lot of folks actually do that on here ...
I think it will depend on your controller, i currently have a 3ware 9500s and nothing but problems with these drives, i will be swapping them with hitachi's to see if that works better
I don't use hardware RAID. I have Linux control my RAID arrays using 'mdadm' which is built into the kernel.
