WD Green - 1TB vs 2TB performance
HardyBoy
How do the WD Greens compare in performance between the various sizes:
WD10EARS - 1TB
WD20EARS - 2TB
TL;DR version: Is the architecture, performance, GB/platter of the Green the same between the 1TB and the 2TB?
I know they are not intended to be performance drives. But the amount of data I will be storing on them is small and I'm thinking that the high areal density of the Greens could make them compare favorably against the dual-proc Black drives.
I did some benchmarks with a dual-proc Black 1TB drive vs a 2TB Green. The Black was faster of course, but not by much AND I got twice the capacity, not to mention cooler temps. And to seal the deal, the Green was about the same price or maybe a bit cheaper than the Black!
I'm now running into a situation where I might want 3 or 4 drives. And thus the question of 1TB vs 2TB Green. Here's the situation: I want to run a virtual server host and have say 3 VMs on each drive. Each VM will only be 40 to 50GB. So max capacity I need is 150GB.
The 1TB Greens are about 60% of the cost of the 2TB ones. So when you multiply that by 4 drives, it's worth thinking about.
But I wonder if they architecture, performance, GB/platter of the Green are the same between the 1TB and the 2TB.
AFAIK, the 1TB models are a lot more reliable than the 2TB models, but for the cost and depending on what you need, the 2TB model may suite you better.
