WD Gold @ 1.5Gbps Mode
l008com
I'm trying to get an old 2009 Apple Xserve up and running. One of the quirks of this system is that the drives have to be in 1.5Gbps mode. If they are in 3Gbps or 6Gbps, even though everything *should* be fully backwards compatible, the systems kind of freak out, and the drives disappear and reappear and cause all sorts of problems. Jumper the drives to 1.5 and presto, everything is perfect.
A few years ago, setting up a different Xserve, I had this exact problem using WD RE drives. Jumpering each one to 1.5 (SATAI) instantly solves the problem, and the drives have been running perfectly non stop for the past 6 years or so.
But now, hard drives come in 6 Gbps. I have a 1 TB WD Gold brand new right in front of me. Before I broke the seal, I looked up jumper settings online. Well it looks like the pins that run a 3 Gbps drive in 1.5Gbps mode on older drives, now puts a 6 Gbps drive into 3 Gbps mode on newer drives. No mention of 1.5 Gbps mode.
Is there any way to do this? Undocumented pin pairs I can jumper? Some other way I can set preferences in the firmware? Something else entirely? Or will I have to buy old stock drives instead for my old server?
I'd say time to look on Ebay for the 2010 version of the Xserve if there is one.
HAHAH. Yeah there's no such thing. 2009 is the newest. It's not a great solution but for right now, it's the least worst one out there, given the costs of collocating a tower, and the unreliability of Mac minis an an off-site data center. This old server will have to do for a little while. And it should do just fine really. Worst case, I need some new-old-stock drives for it. But I suspect there's a way I can get these new drives to work.
Does anyone have a modern WD Red or Ironwolf that you could try before opening the Golds? Not sure if they have SATA speed pins anymore.
Tough call chap! Hope it gets sorted. Always nice to keep good hardware going a bit longer if possible.
Tried the WD Gold tonight, jumpered to 3.0gbps. No-go. Some system spec data implied this machine may have had SATA 3Gbps after all. Looks like it does not.
Welp, after getting "you'll have to call us" responses on WD's email support and forum based support, and after resisting calling them for a week or two, I finally said F-it and gave them a call.
How do you think it went?
If you guessed I talked to someone who barely understood the question, seemed to know nothing at all about the product, except how to follow basic trouble shooting flow charts, you'd be right! In the end, other than some nonsense advice, all I got from calling WD was a link to the general WD SATA jumper setting chart. A page I had seen a million times, that had no useful information on it for my specific question.
So end of the day, all I got from WD tech support was a coordinated effort to waste as much of my time as possible.
As much as I love the idea of a drive with a 128 MB disk cache, this isn't worth the hassle. I'll be returning the WD Gold and getting some old used WD RE4 drives, which should run in 1.5Gb mode without any issues.
