WD Elements 4TB (recert) $89.99 WD Store
Not too shabby, I just bought one of these this past weekend at Fry's "on sale" for $115. And I thought that was a decent price for a 4TB drive.
Quite tempting but ... if it ain't enterprise it ain't worth it (even for 90 USD recert).
Great deal for those tight on cash, hopefully the model of HDD being used in this can hold up for its worth. That would be a lot of data to lose.
if they didn't start soldering those usb ports on them I'd jump all over this...
What do you mean? Can you no longer break it open and get the bare drive out for other uses?
I don't know if it's true for all of their drives, but at least for a lot of them, they don't use a SATA -> USB adapter anymore. The USB port is directly connected to the PCB so you can't use the drive internally.
^ I thought this was the case for all Elements branded WD drives, at least for the past year or two. Don't get me wrong, they're still okay as external drives for the average user, but this deal is just Warm IMO due to slow drive speed and Green/unreliable HDD
I did open up a similar model within the past year (2TB) and I was able to remove the drive from the enclosure. YMMV on these I suppose.
I just saw this as the cheapest 4TB on the market at the moment, despite being "Slow" green drives, they will get the job done, and for inexpensive large external backup capabilities, you won't find anything cheaper/better.
I was able to remove the 4TB drive from the WD Elements I bought over the holidays. That sucks that they're changing that. I mean, they're still selling hard drives, right?
I've only seen that configuration on the 2.5" Passport and Elements branded drives. I've yet to see a 3.5" drive with a USB port soldered to the PCB.
