Little warm Newegg has $10 off and free shipping.
http://www.newegg.com/Product/Produ...10-Index-_-InternalHardDrives-_-22136533-L03A
[Tripod]MajorPayne;1035929586 said:Pretty sure he means it's SATA 3 compatible, I.e. 6 Gb/s max data transfer.
rip off boys, get double the storage for an extra $21
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152232
But that isn't a WD black.
Also not internal.
You wouldn't believe the amount of people on here that upgrade to Sata III motherboards because their mechanical drive is Sata III on it. It's pretty funny. There are some mechanical drives that are pushing Sata II though but I doubt this drive is one of them. A couple of the WD 2TB drives are pushing 150MB/s so you really should have Sata III for those.even it have SATA 3 on it, the bandwidth still cannot exceed SATA 2..
pretty pointless to me.
but the drive itself is awesome though, totally love BC and RE3 series that they have
I'd rather pick up another Samsung F3 1TB for $60 or so when they are on sale.
what is the performance difference between the 2 drives?
