WD Blue 3TB and wdidle3 tool
cortexodus
Has anyone here used wdidle3.exe to set the intellipark timer on the "new" WD Blue drives (the ones which have effectively replaced the green drives)?
I've not found anything online confirming that the "intellipark" feature can be either disabled or at least set to 5min or so on the blue drives. This is something I've done to all of the green drives I've got and it's resulted in a massive reduction in the number of spin-up/spin-downs on those drives.
Thanks!
The new Blue dives, the EZRZ, do not work with that tool anymore I think, as WD ended the Green moniker. However all new Blue drives, except the 10EZEX are 5400RPM.
Too bad. I bought 3 1.5TB greens a few years back and the first time I powered them up was into a dos shell to disable the head parking. All three still churning along years later. It's a shame that WD (and others) use such aggressive head parking. Destroys the drives.
Yes, it was an idea that didn't pay off. Just make it 5400rpm but always on.
Another thing that does help as well is using the enterprise grade RSTe drivers. Doesn't have the driver based head parking enabled. No chirping.
Intel is also now saying this reg edit will disable the head parking/chirping on consumer drivers.
Code:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\iaStorA\Parameters\Device]
"EnableAPM"=dword:00000000
I believe they did that and just called 'em "Red" drives. That's why I'd like to still be able to adjust the head parking on the Blue ones. The greens work really well even as regularly accessed drives as long as that head parking crap is cranked up a bit. Without it, the drives just eat themselves. It's ridiculous to me to have to pay $20 extra for a Red drive which is fundamentally the same gear, but with different firmware.
Code:
I don't even have that entry in registry. Runnig Win7U x64. My rst drivers are from Asus from a z68 board. My mobo is a H57 chipset.
They officially ended the Green. But did they really, or are the Blues just Greens with a rebadge. Old Blues were 7.2k with no intellipark. Greens were always 5.4k with intellipark just like the new blues, looks more like a rebadge.
As far as the tools goes, as long as your data is backed up I would just try it. It will either work or it won't. Just make sure to physically unplug the power from the drive afterwards for 30 seconds to correct issues.
I believe this also about the greens just being rebadged as Blue's now...
Greens were probably cutting into their Red sales :)
So with so many different product lines, Reds, Greens, Blues, Purple's and Blacks.. one had to go.. so they chose the popular Green series
