poddo said:OK, so my side panel is brushed aluminum (its a black praetorian), and I'm cutting a side window. If I use WD-40 to lubricate the cut (with a jigsaw) is that going to affect the paint?
UnknownSouljer said:The Praetorian (even the black one) isn't "painted" and no, you won't have a problem with it.
HOWEVER one thing to note about using a jig saw when trying to make sure the surface of your work peice doesn't get scratched up is tape the shit out of everything. I recommend painters tape, if you don't the trail of the jigzaw tends to leave scratches, something I'm sure you don't want.
