Gongo said:uhh for an fx-53 i assume you have a little money to spend on the cooling? what's the price range? you worried about looks or performance or both? for top of the line cooling i would say Cathar's G5 silver block. but that will be expensive and not availible until jan 05. his G4 line is basically the best on the market right now at around 90 USD shipped i think. the swifty's are ok, but IMO they look like crap. if you have an fx-53 then i'd want something good, but that's me. it all depends on the budget but dont get a kit. DangerDen stuff is pretty good. also depends on what you can fit in your case.
Gongo said:dude you have an fx-53... and only 150 for cooling? uhh that's like someoen getting a ferrari with pleather seats....
bimmer01 said:i might consider a asetek waterchill kit, is that better than the DD setup?
bimmer01 said:I'm new to watercooling parts. One of the worse WC kit i've ever used.
Gongo said:if you dont go with Cathar's Storm G4, go with DD stuff..
btw, how much do you value performance over bling bling? because that also makes a huge difference.
