WC'ing w/ Coolermaster Praetorian
TheToE!
[H] Brewmaster
Has anyone attempted or pulled this off? I want to WC but im affraid the case cant house everything.
I had an Aqua Computer system in my Praetorian and it fit quite nicely. I had a single 120mm Radiator in the top of the case which hung down over the top two drive bays. I also had an Aquatube (reservoir) in the top of the case where the blowhole is. I put the pump (Eheim 1046) on the floor of the case inside the 3.5" drive bays. The Aqua Computer parts kept my gfx card and cpu nice and cool. In fact, during wintertime I was able to turn off the raidator fan and run passive cooling. :cool:
Really depends upon how many drive bays you want to use. My setup left me with two 5.25" drive bays available, both external 3.5" drive bays available, and one or two internal 3.5" drive bays available.
Awsome, thanks for the reply dude! You wouldnt happen to have any pics of that would you? Also can you give a list of parts you used from aqua, or did you have a whole kit? Thanks in advance!
i watercooled my pratoreian, but i used an external enclosure. i personally think it looks much better, but then you have to deal withmoving around an external box. Just thought i would throw that in there.
Thanks, I have thought about an external unit, but I would really like to squeeze everything in there if I could. I think I have an idea of how I could make it work, I just really was hoping someone had some pics of theirs.
I had a worklog going over at a different forum but due to a variety of expensive setbacks I never completed it. Lemme see if I can dig it up and post a link for you...
EDIT: Found the log. Link
Also, a list of the watercooling parts I used (all from Aqua Computer):
Cuplex Pro CPU block
Twinplex GPU block
Aquatube Reservoir
Airplex Evo 120 Radiator
Aquastream pump
Aquaero fanbus and temp monitor
