Hi all.
Besides doing a lot of reading on WCing I'm a WC virgin. However, I plan to change that in the near future. So with that in mind please bear with me if the answers to my questions seem obvious.
My current plan is to initially only WC my Q6600 and an ATI 4870X2. If I push my CPU any further I'll include the NB. My current setup can be found in my signature.
The shopping list:
CPU block: D-TEK FuZion v2 Universal or EK Supreme Universal (evidently the D-TEK doesn't behave with the BP comp. fittings below but there is a new BP 45 fitting that will let it work)
Pump: Laing D5 Vario/Swiftech MCP655 Inline 12V DC
Pump top: EK-D5 X-Top
Rad: Feser X-Changer Triple 120mm
Res: EK-RES250 Rev.2 Multi-Option
Tubing: Tygon A-60-G Norprene (1/2" ID, 3/4" OD)
Fittings: Bits Power Compression Fitting (G 1/4" thread, 1/2" ID, 3/4" OD)
GFX full cover block: Danger Den DD-4870-X2 or EK-FC4870 X2 - CF Nickel
The questions:
Q1: Reservoir should be higher and before the pump input - check. But does the order of devices being cooled (e.g., CPU, GPU, etc.) within a single internal loop (all parts internal to a case) have a large impact on cooling specific parts or does the temperature tend to equalize out? For example, in a single loop (no splits) some people place the CPU before the GPU and vice verse.
Q2: I plan to use BP 1/2" ID 3/4 OD" compression fittings with Tygon 1/2" ID" 3/4" OD tubing. Am I correct in assuming there shouldn't be a fitting issue between two?
Q3: Do pretty much all the custom pump "tops" (e.g., Petra, EK, etc.) support the BP compression fitting I listed above? I originally was going to go with a stock Laing D5 Vario pump but I like the idea of being able to use compression fitting even if it means I have to add a custom "top."
Q4: I'm not interested in dyes but what do you recommend for coolant/additives and why?
Any additional comments are greatly appreciated. Thanks!
The shopping list:
The questions:
