WC'ing my XP2400+ Mobile
TheRapture
OK, all the parts are here. Got to give props to Danger Den, they sent my stuff FAST. :D
I got the Maze4 block and the Hydor L25 pump from Dangerden. I am using a 92mm Vantec Stealth fan @27cfm on a custom made all copper heatercore that measures 4" square x 2" thick. The core was originally designed for a Lian Li drive bay cage, that gives you an idea on the size. The intakes on the front lower part of my Kingwin will supply a shot of fresh air to the Vantec. No true reservoir, just a tall fill tube that acts as a small reservoir and air trap. 1/2" all the way around....
...wish me luck, I hope it will cool my Mobile chip nicely....it should....
ooh i want pics of that heatercore!
Oh and gl ocing the mobile and remember take your time!
