WC'ing loop questions
master6
ok if i wanted to cool 2 9800GTX's, a Q9300, and 4gigs DDR2 1066 with the thermaltake armor LCS with 2 added drive bay radiators/extra pump-res; what would be the best way to arrange my loop?
m6
Loop order doesn't matter...
But, thermaltake is a POS company, expect to spring leaks within 6 months.
Can't you get a better company to provide your WC gear?
idk i just like the concept of a built in WC'ing system. if you have got better please tell me. the Gigabyte Mercury 3d pro is also pretty appitizing. i dont have the money for the setup right now but its my "dream comp" that i constantly update and i thought it would be good i f i learned more about WC'ing before i actually commit to buying a system that has it.
Any of those premade kits you mentioned are pretty terrible. If you want a kit, look at the swiftech APEX or petra's tech kits.
i dont really want an external setup though. thats why i was looking at those cases.
Imo, the ideal loop is reservoir (if you use one) > pump > rad > cpu > gpu. To me that's ideal, but sometimes spacing and arrangements make it hard to get this loop.
The problem with built in systems is that that they almost always under perform (read: worse than air) and are often louder due to cheap components/fans.
There are numerous cases that can mount double or even triple rads without any modification. For example, cooler master 590/690 + cosmos.
what about the antec twelve hundred? it looks like it would work but im not quite sure.
