For my next build I'm thinking about going mATX in an X-QPACK2. I would like to WC the CPU only, and I would like to do it with a minimum of case modding. Would the following loop squeeze into that case?
Danger Den db-1 pump
Swiftech 1x80 or 1x120 rad
D-Tek Fuzion v2
Switftech MCRES-Micro or 3.5" bay reservoir failing that
My largest concern is where the radiator would fit and how to mount it. I'm not averse to drilling a few holes if I have to and I'm thinking about replacing the windows with mesh anyway, so maybe I could put pushpins through holes in the mesh depending on how strong it is? Any thoughts on that?
And would this be a good enough loop to beat good air cooling? Bear in mind that top-of-the-line air coolers are much too tall to fit in that case without Dremeling out part of the right-hand support bar, so I'd have to find someone's Dremel to borrow or be limited to a low-profile Zalman or something.
D-Tek Fuzion v2
