I'm building a new system to tote around for lans and what not (yeah toting + watercooling, probably not the best idea, but ahh well). It's going to be a small form factor fly. The vid card will be a R2900pro, and I'm not entirely sure if I'd like to cool it in the loop as well. The proc will be a G0 q6600, and I'm hoping it'll be running at 3.6.
Now the biggest question I have on the system will be rad size and placement. With doing something like this on a small form factor case, is it best to build an external unit to house the components and allow for a bigger radiator?
For the main system, I'm planning on filling the 2x5.25" bays with 3x hotswap drives, and leaving the 2x3.5" internals empty. I was thinking about building a case the same size and 1/2 height to sit underneath the fly case, with "rubber standoffs" to clear the case maybe an inch - and the posibility of using disconnects, but probably not since there will be such little clearance between the case and box. The radiator would probably be mounted at the top center of the "box", as the back wouldn't allow a 3x120mm radiator.. but do I really need one, or will a 2x120 be more than sufficient?
