I am dreaming about WCing my rig since I have seen that thread but then I realised he cut off the top of the case which I don't wanna do. So I'm trying to find a way to do a internal CPU/GPU loop. The goal is to have a little challenge and if possible a near silent case when idling/downloading so I can let it run while I sleep without modding the exterior of the case.
The only idea I have for the rad is : (I don't even know if that exist):
Does it look doable, any suggestion? I can laser cut custom plate to fasten the fan/rad for free but I'm concerned about room.
- 200.1 rad or 82.4 rad or 4x82.1 rad with 8x82mm in push-pull config
- high FPI 120.2 with 4x120mm in push-pull config but looking at his picture I don't think it would fit with the middle drive bay
